Encontrei quase todos os campos do sys.txt, segue para aquele interessados, mas lembre-se é para montar seu arquivo, se por no seu GPS provavelmente não funcionará corretamente:
Código: Selecionar todos
[2d]
carcenter_x=-1 ;(-1)
carcenter_y=30 ;(-1) 0=top of arrow
mincarsize=100 ;()
mincarsize_zoomlevel=5000
maxcarsize=180 ;()
maxcarsize_zoomlevel=200
draw_polygon_contours=0 ;(1) more speedy
guidancestrip_thickness=0.4 ;(0.4) strip width
guidancestrip_outline_thickness=1 ;(2) not in 3d
guidancestrip_width=0.9 ;(0.5) arrow head width
show_guidance_arrows=0 ;(1)
[3d]
disable_car_normals=1 ; mdl surface normals discard
ambient=x00900190 ;(0x00000190)
globe_ambient=x000003D4 ;(0x3d4 blueish)
distance_terrain_resolution=1 ;(0)
show_guidance_strip=1 ;(1) colors guidancestrip and guidancestrip_ext
guidancestrip_thickness=0.1 ;(0.1) strip width
guidancestrip_width=0.6 ;(0.5) arrow head width
guidancestrip_elevation=0.08 ;(0)
show_guidance_arrows=0 ;(1) colors in day[night]2d[3d]color.ini
guidancearrow_first_size=1.5 ;(?) scale of 1st arrow
guidancearrow_first_alpha=20 ;(20) transp of 1st arrow
guidancearrow_second_size=1.0 ;(?)
guidancearrow_second_alpha=10 ;(10)
use_all_building_textures=0 ;(1) less memory
min_poly_segments_shown_1=200 ;makes map drawing a lot faster
max_poly_segments_shown_1=400 ;makes map drawing a lot faster
;### fading buildings when click 3d map
fade_around_cursor=1 ;(0) buildings fade when map clicked there
fade_use_overlap=1 ;(0)
fade_distance_for_car=50 ;(20)
[3d_config]
roadsign_lines_per_screen=14 ;(30) max streetnames on the screen, affects fontsize in 3D
disable_roadsign_navigation_mode=0 ;(1) nice text balloons roadnames in nav mode
rotated_roadsigns=1 ;(0) roadnames will align with the roads themselves
frame_fontsize_muler=1.0 ;(1.0) label font factor, CONFIG\DEVICES INI file
;roadsign_lines_per_screen=16
[config]
R2L=0
autoset2donmap=1 ;(0)
autoset3doncockpit=1 ;(0)
HideRoadAltName=0 ;(1)
nmaxstrapdistance=22 ;(30) radius for snap gps pos to the road (22 also OK), see [strapon]
[debug]
;### this creates detailed running logfile for tts etc
;log_1="\Storage Card\igo8\igo8_debug.log::5"
logitiner=full ;off
skip_platformlock=1 ;(0) hmmm...
screen_calibration=1 ;(?) force screen calib option
getupdates=0
minimize_button=1
adaptive_2d=1 ;(0)
raster_quality=1 ;(2)
BuildNewOrderList=1 ;(0)
phone_available=1 ;(0)
bluetooth_available=1 ;(0)
render_without_focus=1 ;(0) renders even if igo8 window not in front
reserve_memory=2097152 ;(0) default 4Mb, don't use less that 1Mb (1mb=1048576 2mb=2097152 3mb=3145728)
;### moved fov to DEVICE INI 40 for 320x240, 50 for 480x272
;fov=45 ;(45) field of view (wider angle=slower, 3d car smaller)
;### TTS settings
tts_min_ready_wav=1 ;(0)
tts_getaway_time=400 ;(0)
tts_expected_engine_delay=1200 ;(0)
auto_ignore=1 ;(0) tts intelligence?
;### end TTS
min_then_dist=20 ;(0) don't use 2nd call if less than...
tmc_all_stations=1 ;(0)
immediate_distterrain_dem=1 ;(0)
skip_eula=1 ;(0)
smart_2d=1 ;(0)
earth=1 ;(0)
show_truck_info=1 ;(0)
;show_screensize=0 ;(0)
;show_arrows_on_route=1 ;(1) little arrows in direction of route
show_plural=1 ;(0) color road on slippery places
;show_residentonly=0 ;(0)
show_multinode_maneuvers=1 ;(0)
show_prohibited_maneuvers=0 ;(0)
show_priority_maneuvers=1 ;(0)
show_turn_penalty=1 ;(0)
show_lane_info=1 ;(0)
show_gps_pos=1 ;(0) little blue dot
show_signpost=1 ;(0)
show_original_signpost=1 ;(0)
show_pedestrian=1 ;(0)
;show_segmentdir=0 ;(0)
;show_segmentid=0 ;(0)
;show_oneway_3d=1 ;(1) 3d arrows in one way streets
show_oneway=1 ;(0) show one way on or off
;show_uturn=0 ;(0)
;show_mapid=0 ;(0)
show_tmc=1 ;(0)
;show_performance=1 ;(0) cpu / mem / whatever bars on top of screen
;show_device_type=1 ;(0) handy for finding proper CONFIG\<device.ini>
show_rawdisplay_info=0 ;(0) handy for seeing what igo chooses as display driver
show_prec_poi_detour=1 ;(0)
;show_lights=0 ;(0)
;show_ltn=1 ;(0)
show_roadid=1 ;(0)
show_historical_speed=1 ;(0)
show_speed_limit=1 ;(0)
autosave=10000 ;(60000) save state every minute
disable_outlookpoi=1 ;(0)
;show_turn_penalty=1 ;(0)
turn_penalty_multiplier=90 ;(100) bigger means less turns
[feature]
tunnel_guidance=1 ;(0)
itiner_cityentry=1 ;(1)
signpost_coloring=1 ;(0)
tmc_event_coloring=1 ;(0) see day/night/2d/3dcolor.ini etc for tmc_event_color0..4
tmc_traffic_side=1 ;(0)
tmc_show_direction_arrows=1 ;(0)
[folders]
app="%SDCARD%/iGO8" ; change this if applicable
data="\Storage Card\iGo8"
;demo="DEFAULTS\demo" ; route???.dat
kmlpoi="userdata\poi" ;"content\userdata\poi"
kmlroute="userdata\route" ;"content\userdata\route"
tts_nuance="\Storage Card\iGO8\ScanSoft\RealSpeakSolo" ;(\ResidentFlash\ScanSoft\RealSpeakSolo) ezrider3
;tts_nuance="\Storage Card\MioMap\TTS_PPC"
tts_loq="\Storage Card\IGO8\TTS_LOQ" ;becker
[gps]
;default_latitude=48.857004
;default_longitude=2.294760
read_total_timeout=50 ;(100)
read_buffer_size=512 ;(256)
internal=0
;port=2
;port=1
;baud=4800
;protocol="auto" ;("auto") nmea sirf hippo
;devicename_template="COM%d:" ; so port=1 becomes COM1:
;send_init=0 ;(0)
;use_trickle_power=1 ;(0) only Sirf?
;maximise_baud=0 ;(0)
;set_messages=1 ;(1)
[interface]
; This threshold determines the roadname length above which
; no roadshield is shown in TMC list but roadname is merged into Location Info
; set -1 to always show roadshield, set 0 to always show merged string
tmc_roadname_length_threshold=-1
save_checksum=0
unreachable_viapoint_as_target=1
emptylist_counter="1/1" ;("0/0")
emptylist_page_count=1 ;(0)
emptylist_page_number=1 ;(0)
compass_velocity=20 ;(10)
shutdown_time=0 ;(10) no shutdown timer!
;round_mode=1 ;(0) dunno
use_mixed_country_state_list=1 ;(0)
city_hist_maxentriesnum=40 ;(18)
show_detailed_posinfo=2 ;(0) like postal code
bilang_city=1 ;(0) show cityname in your and orig language
skin=ui_igo8
;skin=ui_igo8_da
;skin=ui_igo_easy
;skin=ui_magellan
;skin=ui_becker
;skin=ui_blaupunkt
;skin=ui_mio_v5
;skin=ui_pioneer
;skin=ui_hp_sagan
;skin=ui_alpine
;skin=ui_limo
;resolution_dir=240_320
;resolution_dir=320_240
;resolution_dir=480_272
;resolution_dir=800_480
minzoomglobe=100000 ;() 100km 2d zoom before switching to globe view
minzoom2d=100 ;(100) tested!
;maxzoom2d=60000 ;(0)
defaultzoom2d=10000 ;(20000)
defaultzoom3d=50 ;(100) bigger than [map]3d_min_zoomlevel
;defaulttilt3d=7500 ;(6000) same as [map]3d_default_tiltlevel
initial_zoom_level=5000 ;(40000)
autotilt=0 ;(0) 1 2 makes the camera go up and down
;autotilt_minzoom3d=20 ;(20)
;autotilt_maxzoom3d=400 ;(400)
rotoffset=20 ;(8)?
show_orientation=1 ;(0)
show_calibration=1 ;(0)
show_gps_config=1
show_tmc_config=1
show_exit=1
show_minimize=1
show_zoombar=1 ;(0) also see zoomscale_disappearing
show_kml_type=1 ;(1)
mapfontscale=140 ; for 2d map (area,road,label?)
default_poi_icon="Contacts" ; see icons\poi\contacts.icon
drive_carefully=0 ;(1)
use_spec_fav=1 ;(0) Home and Work?
spec_fav_count=2 ;(2) Home and Work?
;check_bt_pairing=0
;bt_pairing_window="Enter Passcode"
[itiner]
pass_via_distance=1 ;(0)
pass_destination_distance=1 ;(0)
pass_stop_speed=1 ;(0)
show_only_till_next_viapoint=0 ;(0)
show_prev_manuevers=1 ;(0)
show_only_ahead_of_car=1 ;(0)
[keyboard]
panel_alpha="US English (QWERTY)"
panel_custom="Numbers"
[loading]
;### read from UI file with GetSysEntry
usermode=0
show_statustext=1
show_progressbar=0
progressbar_x=85
progressbar_y=134
;loading_bmp="loading.jpg"
;text_fontcolor=xFFFFFF
;text_fontsize=30
;text_x=100
;text_y=400
;text_w=600
;text_align: LEFT = 0,CENTER = 1,RIGHT = 2 JUSTIFY = 3
text_align=1
[local]
dateformat=6 ;(dd-mm-yyyy)
timeformat=0 ;(24h)
;default_language="english GB"
default_language="dutch NE"
;voice_key="tts_nua_dut_f1"
voice_key="tts_loq_dut_f4"
[map]
sieve_mode=0 ;(1) 0=wireframe faded buildings, separate what?
alternative_roadnames=1
2dheadup=1 ;(0) extra 2d heading/north
map_mode=3D
zoomfactor=105 ;(<100 or >100)
tiltfactor=30 ;(150) below 100 smaller tilt steps
;tiltmaxcount=120 ;(100)
;minimum_zoom_amount=70 ;(2)
zoom_handler_click_time=200 ;(100)
3d_zoomfactor=105 ;(<100 >100) below 100 smaller zoom steps
show_labels=1 ;(1)
show_labels_in_2d=1 ;
show_labels_in_3d=1 ;
poi_grouping_distance=0 ;(??)
;poi_distant_zoomlevel=5000 ;(3000)
poi_iconid_distant=1 ;(0) see ui_igo8\icons\poi\poi.icons 1st line
poi_iconid_near=1 ;(1) see ui_igo8\icons\poi\poi.icons 2nd line
roadblockicon_maxzoom=2000 ;(?) tmc icons visible zoom
zoomscale_disappearing=1 ;(0) works with show_zoombar
textured_poly=0 ;(1) doesn't matter, igo always set it to 1
;terrain_in_2d=1 ;(1)
3d_buildings_distance=3 ;(1) far
;### only if smartzoom is not on
3d_min_zoomlevel=20 ;(30) see also [smartzoom] min/maxzoom
3d_max_zoomlevel=500 ;(600)
3d_max_tiltlevel=8200 ;(7800) see sky or not?
3d_default_tiltlevel=7800 ;(6000) between min and max [interface]defaulttilt3d
3d_max_zfar=256 ;(64) draw planned road ahead?
3d_scale_carmodel=1 ;(1)
3dcarsizemin=6000 ;(10000)
3dcarsizemax=12000 ;(28000)
3dcarsizemul=40000 ;(40000)
maxFovRatioForPoly=3 ;(5)
;max_road_segment_count=1000 ;(2000) faster!
max_road_segment_count=500 ;(2000) faster!
[msnd]
; Set msnd.start=0 to disable
msnd.start=0
[modules]
;IPOWER_DRIVER="PDA_POWER_DRIVER"
IPOWER_DRIVER="WINCE_POWER_DRIVER"
IBATTERY="BATTERY_MONITOR_WINCE"
[mydata]
use_home=1 ;(0) defaults\user.upoi
use_work=1 ;(0) defaults\user.upoi
max_favorites=99 ;(30)
empty_favorites=1 ;(1) allow favorites to be empty
max_histories=99 ;(?)
num_favicons=7 ;(0) UI_IGO8\ICONS\FAVICON\1 2 3 4 5 6 7.ICON
[mydata.tracks]
auto_track_visible=1 ;(0)
record_auto_track=0 ;(0)
;[mydata.truck]
;default_profile="default"
;selected_profile=0 ;(-1) from truck_profiles.ini
;drive_alone=1 ;(1)
;selected_driver=0
;driving_timer_allowed=1 ;(1)
;max_driving_time= ;(0xF70000)
;max_daily_driving_time= ;(0x1EE6280)
;min_break_time=
;max_break_time=
;pre_warn_time=
;start_stop_limit=15 ;(15)
;### truck_prolifes.ini
;## vtr
;## hazard
;## icon
;## trailers
;## axles
;## actualweight
;## maxspeed
;## weight
;## height
;## width
;## length
;## name
[navigation]
direction_notify=1 ;(0) like start_ne start_se start_n in voice.zip commands.csv?
;onlyguidancetime=5 ;(0) skip to secs before next maneuvre
;onlyguidancedist=500 ;(100) when simulate skip to distance before next maneuvre
no_road_rotate_speed_min=20 ;(10)
waypoint_radius=800 ;(300) waypoint visited if < 300 mtr?
sim_speed_factor=4 ;(1?)
show_countrychange=1 ;(0)
autoreplan_action="AUTO" ;(ASK AUTO OFF)
maneuver_near_threshold=1000 ;(1500)
second_maneuver_near_threshold=1500 ;(1800)
can_pass_via_from_itinerconfig=1 ;(0)
[other]
demo_mode=1 ;(0) enables demo route mode
;alpine=1 ;(0) enables alpine fm transmitter?
[other.fm_transmitter]
fmtx_enabled=0
;min_freq=
;max_freq=
;store_slot_max=
;fmtx_current_frequency=
[other.highway_drive]
enabled=1
use_signposts=1
calculate_simulation=1
poi_search=1 ;()
;poi_search_area=1500 ;()
;planned_route_only=1 ;()
;precog_distance=
;filter_by_pois=
;poi_category_list=""
;signpost_description_max_items=
poi_search_category0="Gas_Station"
poi_search_category1="Parking"
poi_search_category2="Restaurant"
poi_search_category3="Hotel"
[other.magellan]
demo_mode_restart_timeout = 10800
offroute_max_cnt = 3
offroute_timeframe = 60
[poi]
use_multi_poi_icon=0 ;(1)
show_poi_areas=1 ;(0)
use_lastknowngps=1 ;(0)
inherit_visibility=0
default_visibility_altitude=3000 ;(?)
; Airport, Business, Car_Dealer_Repair, Communication, Community, Finance Leisure
; Medical, Nature, Parking, Petrol_Station, Rent_A_Car, Restaurant, Shopping, Sport
; Tourist_Attractions, Transportation
sort_order="Petrol_Station,Parking,My Poi,Restaurant,Shopping,Accomodation,Medical" ;("Restaurant,Accomodation,Petrol_Station,Parking,Medical")
priority="Petrol_Station,Parking,My Poi,Restaurant,Shopping,Accomodation,Medical" ;("Restaurant,Accomodation,Petrol_Station,Parking,Medical")
sort_by_config=1 ;(0)
userpoi_has_mypoi=1 ;(0) see mydata use_home use_work
enable_pois_before_080217=0 ;might cause crash!
detour_interval_1=5000 ;(300)
detour_interval_2=10000 ;(1000)
detour_interval_3=30000 ;(5000)
kmlpoi=1 ;(0) in content\userdata\poi
kml_draw_as_multipoi=0
kml_show_folder_icon=1
kml_show_please_wait=1
[power]
;sdcard_remove_onsuspend_ignore=1 ;(0)
powermgm_state=1 ;(0) smart
;battery_shutdown_delay=30 ;(10)
;allow_battery_full=1 ;(0)
;battery_full_hyst=3 ;(2)
;battery_low_hyst=3 ;(2)
;battery_critical_hyst=3 ;(2)
backlight_manage_values = 1
backlight_manage_keys = 1
backlight_min = 30
backlight_max = 255
backlight_reverse = 0
backlight_key_bright_BA1 ="BATLevel"
backlight_key_bright_AC1 ="ACLevel"
backlight_key_Bright_BA2 ="BacklightLuminanceLevel"
backlight_key_Bright_AC2 ="ACBacklightLuminanceLevel"
backlight_key_timeout_BA = "BatteryTimeout"
backlight_key_timeout_AC = "ACTimeout"
backlight_key_ontap_BA = "BacklightOnTap"
backlight_key_ontap_AC = "ACBacklightOnTap"
backlight_key_on_BA = "BatPowerOn"
backlight_key_on_AC = "ExtPowerOn"
;### now cause suspend/resume problem
;backlight_methods = 1, 5, 7
;backlight_events = 1, 2
backlight_day=255
backlight_night=30
[project]
;name=xxxxx ; default data.zip\project_config\igo8_generic.INI
name=igo8_generic.INI
;name=igo_easy.ini
;name=pioneer.ini
;name=magellan43xx.ini
;name=becker.ini
[rawdisplay]
class="auto"
[roundaboutcam]
enabled=0 ;(1)
centery=70 ;(50) cam angle @ roundabout
[route]
;### If you change any of these !!!!! delete .\SAVE\Route.dat first !!!!!
correctness=95 ;(90) see also [defaults] mainroadness etc...
route_type=ECO ;(FAST,ECO,SIMPLE,SHORT,SCENIC)
planned_route_weight=1 ;(7) 0 to 10 Off Route Sensitivity (route.planned_route_weight)
use_tmc=2
sort_cityresult_by_gpsdistance=1 ;(0)
allow_unpaved=0
allow_highway=1
allow_ferry=1
allow_charge=1
allow_uturn=0
allow_special=0
allow_carpool=0
cross_border_routes=1 ;(1)
slow_car_speed=60 ;(80) eta, route time calc?
slow_car_multiplactor=80 ;(80)
fast_car_speed=100 ;(130)
fast_car_multiplactor=100 ;(100)
motorcycle_speed=120 ;(130)
motorcycle_multiplactor=100 ;(100)
offroad_speed=20 ;(30)
continue_with_ferry=1 ;(0)
max_endpoint_distance_km_pedestrian=100 ;(0)
max_endpoint_distance_km_bicycle=200 ;(0)
max_endpoint_distance_km_shortest=1500 ;(0)
max_endpoint_distance_km_limited=1500 ;(0)
max_endpoint_distance_km=2000 ;(0)
permit_penalty=1000 ;see [truck]
charge_penalty=1000 ;(0)
toll_penalty=0 ;(0)
bridge_penalty=100 ;(0) in meters?
tunnel_penalty=200 ;(0)
uturn_penalty=5000 ;(1000)
[route.histspeed]
enabled=0 ;(1)
show=1 ;(0)
use_timeslice=1 ;(0)
[route.histspeed.timeslice]
day=0 ;(0)
hour=0 ;(8)
minute=30 ;(0)
[settings]
all_map=1 ;(1) show all on map (all event types)
[scheduler]
disable_smooth_anim=1 ;(0)
[screen]
menu_animation=0 ;(0)
[smartzoom]
;## smartzoom tilt starts in 850 mtrs before next maneuvre
;use2d is to use separate smartzoom for 2d and 3d.
;Once this is implemented in a UI it should be set to 1.
use2d=1 ;(1)
auto_follow_on=1 ;(1)
auto_follow_time=10 ;(10) sec
restore_smartzoom_on=1 ;(0)
auto_smartzoom_time=10 ;(10) sec
zoom_after_find=1 ;(1)
autozoom_address=300 ;(700)
autozoom_coord=1000 ;(8000)
autozoom_cos=1000 ;(8000)
;### 2D smartzoom
enabled2d=1 ;(1)
minzoom2D=100 ;(200) zoom in level 2d
maxzoom2D=1500 ;(1000) zoom out level
zoom2dpercent=135 ;(135)
;### 3D smartzoom
enabled=1 ;(1)
minzoom=60 ;(60) not <60 not smaller than 3d_min_zoomlevel
maxzoom=120 ;(300) not bigger than 3d_max_zoomlevel
minangle=35 ;(45) like 3d_default_tiltlevel (8000) from top
maxangle=85 ;(70) horizontal
angleoffset=10 ;(10)
percentage=70 ;(100) also search ui's for .smartzoom.percentage
;### overview
overview=1 ;(0)
overview_zoomlevel=2500 ;(2816)?
overview_distance=10000 ;(4000)?
[sound]
queue_length=200
ding=0 ;(1)
sound_volume=255
voice_volume=255
sound_muted=0
voice_muted=0
dynamic_volume_minspeed=60 ;(90)
dynamic_volume_maxspeed=130 ;(150)
dynamic_volume_voicemaxspeed=80 ;(120)
dynamic_volume_voice_volume_max=75 ;(64)
dynamic_volume_os_volume_max=255 ;(255)
incomingcallsetting=1
device_id=0
use_os_volume=1
;use_method=5
[sound.announcer]
recalculate=1
ask_recalulate=1
offroute=1
overspeed=1 ;(1)
gps_disconnected=1 ;(1)
gps_signal_lost=1 ;(1)
mute_all=0
muted=0 ;(0)
;[speedcam]
;import_directory="\Storage Card\poi\speedcam" ; from ezrider r
;disable="_USA,_CAN,_u**,_ual,_uak,_uak,_uaz,_uar,_ucx"
[strapon]
;discard_state_timeout=60000 ;(30000) 30 secs
max_position_distance=400 ;(300)
min_gps_precision=50 ;(0) gps.accuracy
max_gps_precision=100 ;(0) gps.accuracy
;min_discard_prob= 0.0 ;(????)
;min_distance_for_move_at_low_speed=20 ;(20)
;max_speed_for_stop=0 ;(0)
min_distance_for_switch_off_stopping=50 ;(100)
min_speed_for_release_stopping_off=2 ;(10)
[timezone]
default_timezone=29 ; GMT+1 amsterdam
index=29
sync_time=1
reset_os_timezone=0
sync_os_timezone=1
use_auto=1
manual_dst=0
tzdst=0
use_new_timezone_ini=1
keep_auto_on_error=1 ;()
[tmc]
;###GETSYSENTRY
show_tmc_settings=1
use_tmc_subscription=1
;init_on_startup=1 ; set in CONFIG\DEVICES INI
reinit_on_hardware_lost=1
enable_subscription=1 ;(0) subscibe button in tmc config
auto_tuning=1 ;(0)
auto_calc_detour_event=0 ;(0) type of events?
auto_detour_calc=0
calc_detour_route=3 ;(0) auto(0) off(2) ask(3)
announce_total_route=0 ;(0) only announce what is in front?
enable_flow_icons=1 ;(0) need $traffic_speed.spr
events_custom_color=1 ;(0) see day2dcolor.ini/day3dcolor.ini tmc_event_color0 ...
enable_flow_events=1 ;(0) haven't seen any flowing
flow_stripe_width=6 ;(6)
flow_stripe_offset=0 ;(0)
flow_stripe_blinking_time=1000 ;(0) in msecs
;cache_root="content"
;cache_name="tmc/tmccache" ;(?)
flow_limit_low=15
flow_limit_high=45
;### extra settings ezrider r3
enable_flow_lines=1
disable_fast_flow_lines=1
hide_fast_speed_values=1
flow_line_width_from_viscfg=1
flow_line_offset_from_viscfg=1
flow_line_blinking_time=1500
disable_fast_flow_icons=0
flow_icon_zoom_big=500
flow_icon_zoom_med=3000
flow_icon_sprite_big="$traffic_speed_big.spr"
flow_icon_sprite_medium="$traffic_speed.spr"
flow_icon_sprite_small="$traffic_speed_small.spr"
flow_icon_fontname = "tahomabd"
flow_icon_fontsize_big = 16
flow_icon_fontsize_medium = 0
flow_icon_fontsize_small = 0
flow_icon_offset_from_viscfg=1
port="COM,4"
baud=38400
source="gnsport" ;harman eten galik opentmc2 opentmc1 hyundai samsung amaryllo royaltek gns
init_on_startup=1
tuner_alg_search_force_on=1
tuner_alg_search_timeout=10000
tuneralg_rds_packet_timeout=6000
tuneralg_8a_packet_timeout=6000
tuneralg_3a_packet_timeout=20000
tuneralg_last_8a_packet_timeout=10000
;### use=1 overrides all vehicles, better use SAVE\truck_profiles.ini method
[truck]
vtr=519 ;default truck VTR
max_restriction_level=0
;use=1 ;(?)
;weight="10000" ;(?)
;weightperaxle="2000" ;(-1)
;loadtype="-1" ;(-1)
;maxspeed="90" ;(?)
;length="15" ;(?)
;width="3.5" ;(?)
;height="4.5" ;(?)
;max_restriction_level="2" ;(0)
;vtr="1"
;hazmatflags="5" ;Hazardous Materials 0-6
;### see also [route] permit_penalty=2000
[tts]
automatic_direction_conversion=1 ;(1)
tts_buffer=131072 ;(32786=32k)
announce_exit_directions=1 ;(0)
tts_logics=6 ;(2)
priority="HIGH" ; ezrider r3
always_say_road_names=1 ;(0) 1 or 2 or 3
skip_exit_numbers=0 ;(0) 1 or 2
[warning]
speedcam_enabled=1 ;(0)
speedcam_visualtype=1 ;(1)
speedcam_soundtype=1 ;(1) 1=warn if overspeed 2=approach
speedcam_warning=1 ;(0)
speedlimit_warning=1 ;(1)
speedlimit_warning_voice=1 ;(1)
speedlimit_warning_visual=1 ;(1)
speedwarn_alt_builtup_based=1 ;(0)
speedwarn_alt_limit=1 ;(0)
speedwarn_alt_tolerance=110 ;(100)
speedwarn_alt_toltype=1 ;(0) alternative tolerance type
speedwarn_tolerance=110 ;(100)
speedwarn_toltype=1 ;(0) absolute or percentage
lowspeed_warning=0 ;(1)
lowspeed_toltype=0 ;(0) percentage
lowspeed_tolerance=20 ;(20)
pedestrian_warning=0 ;(1)
pedestrian_warning_threshold=40 ;(40)
speedwarn_voice_rewarn_toltype=1 ;(0)
speedwarn_voice_rewarn_tolerance=110 ;(-1)
;approach_beep_distances="8,16,24" ;("8,16,24")
warn_distances="100:600,80:400,60:300,40:100" ;("110:1000,80:800,60:500,40:300") speed:distance
;approach_beep_sound="!sectionbeepB" ;(!sectionbeepB) speedcam approach sound
overspeed_sound="!oasis_alarm1" ;(!alert5) speedcam sound
speedcam_max_angle=44 ;(20) degrees?
speedcam_snap_distance=25 ;(25) snap what?
speedcam_max_lookahead=500 ;(1000) check for cams 500 mtr ahead
speedcam_maxdistance_from_road=30 ;(50) ignore speedcams more than 20 meters from the road
;section_beep_distance=50 ;(100) only beep 50 mtr before
;max_section_time=240 ;(600) max beep time 240 secs
;section_beep_sound="!sectionbeepA" ;(!sectionbeepA)
;section_start_sound="!sectionstartA" ;(!sectionstartA)
;section_end_sound="!sectionend" ;(!sectionend)
[warning.driveralert.settings]
max_display_count=2
show_timeout=10
show_vehicle_pictograms=1
;truck_policy=
;show_cat=
;warn_cat=
;warn_method=
;enum_all_devices=0
;devicename="Becker TA"
;pairpin="0000"
[phone]
;sms_cmd="hello"
;phone_msg_type=1
;start_bt_at_startup=1
;default_bt_state=0
;default_phone_state=2
driver="IVT"
;driver="FAKE"
;devicename="Compasseo 800"
;### BlueSoleil (SAMSUNG)
;exe_path="\Windows\BlueSoleil.exe"
;win_name="Bluetooth Manager"
;win_name="EMPTY"
;class_name="IVT Bluetooth Software"
;switch_name="-m"
;-s is static config
;-m start dialer
;class_name="EMPTY"
;### IVTDialor (IVT)
exe_path="\Windows\IVTDialor.exe"
win_name="EMPTY"
class_name="IVTDIALOR"
switch_name="-m"
; Possible PHONE/BT providers (driver="ROUTON")
; BASE ASUSHF AVT BCE BRASALFA BT FAKE GSAT HF IGOMGS
; IVT NFORCE NGALINK TAPI PHONELINK ROUTON SAMSUNG SOL
