aviso de radar
Enviado: 26 Set 2012, 17:38
Estou usando o igo amigo,com o skim tunado mas fala radar quando saio de casa quando chego em casa não tem radar na minha rua,e quando ligo o gps e na simulaçao, vou ate mostrar meu sys no caso de alguem resolver ajudar.
[interface]
resolution_dir="400_240"
maxzoom2d=6000000
show_exit=1
extra_settings=1
laneinfo_signpost_enabled=1
signposts_without_laneinfo=1
shutdown_time=0
[rawdisplay]
screen_x=800
screen_y=480
highres=1
[folders]
has_secondary_root=0
[debug]
skip_eula=1
enable_roadshadow=1
show_performance=0
reserve_memory=1572864
cache=131072
show_junction_view=1
[loading]
show_statustext=1
show_progressbar=1
text_fontcolor=0
text_w=380
[3d_config]
disable_roadsign_navigation_mode="1"
show_guidance_strip="1"
roadsign_lines_per_screen="14"
rotated_roadsigns="1"
use_all_building_textures="1"
fade_distance_for_car="50"
fade_distance_for_guidance_arrow="500"
fade_overlap_tolerance="0"
[feature]
signpost_coloring="1"
text_guidance="1"
[map]
show_labels="1"
show_oneway="1"
alternative_roadnames="1"
3d_scale_carmodel="1"
3dcarsizemin="20000"
3dcarsizemax="28000"
3dcarsizemul="24000"
[navigation]
autoreplan_action="AUTO"
sim_speed_factor=2.5
show_current_city=1
show_countrychange=1
simple_crossborder_warning=1
show_city_in_next_street=1
show_city_in_next_street_distance=1000
roadsign_lines_per_screen=22; para aumentar a fonte do nome de ruas, quanto maior o número menor a fonte
junction_view_at_maneuver=1
junction_view_type="mixed"
[roundaboutcam]
enabled=0
centery=20; comando utilizado para que o cursor acompanhe o trajeto em uma rotatória
[tripcomputer]
num_of_trips=3
[2d]
mincarsize=1000
maxcarsize=1800
[poi]
multipoi="1"
[sound]
queue_length=200
os_volume="255"
sound_volume="255"
voice_volume="255"
csv_voice_enabled=1
ding="0"
[tts]
tts_buffer="40000"
announce_exit_directions="3"
tts_logics="3"
priority="HIGH"
always_say_road_names="3"
announce_street_name="1"
skip_exit_numbers="1"
[warning]
speedcam_visualtype="1"
speedcam_warning="1"
speedcam_soundtype="2"
speedcam_enabled="1"
speedcam_maxdistance_from_road="55"
speedcam_max_lookahead="600"
speedcam_max_angle=120
speedwarn_toltype="1"
speedwarn_alt_toltype="1"
speedwarn_alt_tolerance="135"
speedwarn_tolerance="125"
warn_distances="130:550,110:450,90:400,70:350,40:250"
approach_beep_distances="50,90,150,250"
speedlimit_warning="0"
speedlimit_warning_voice="1"
overspeed_sound="!alert5"
approach_beep_sound="!ding"
[timezone]
use_auto="0"
sync_time="1"
reset_os_timezone=1
sync_os_timezone=1
[mapswitch]
1=",map_ta,\ResidentFlash\Amigo,0,"
2=",map_nt,\ResidentFlash\Amigo,0,"
3=",map_ot,\ResidentFlash\Amigo,0,"
SDMMC\Amigo\amigo.exe
[utility]
utilitymov=",1,\ResidentFlash\Amigo,"
utilitydel=",2,\ResidentFlash\Amigo,"
[interface]
maxzoom2d=6000000
show_exit=1
extra_settings=1
shutdown_time=0
[rawdisplay]
screen_x=800
screen_y=480
highres=1
[folders]
[debug]
skip_eula=1
enable_roadshadow=1
show_performance=0
cache=131072
[loading]
show_statustext=1
show_progressbar=1
text_fontcolor=0
text_w=380
[3d_config]
[feature]
text_guidance="1"
[map]
show_labels="1"
show_oneway="1"
[navigation]
show_current_city=1
[roundaboutcam]
enabled=0
[tripcomputer]
num_of_trips=3
[2d]
mincarsize=1000
maxcarsize=1800
[poi]
multipoi="1"
[sound]
queue_length=200
os_volume="255"
sound_volume="255"
voice_volume="255"
csv_voice_enabled=1
ding="0"
[tts]
tts_buffer="40000"
tts_logics="3"
priority="HIGH"
[warning]
[timezone]
use_auto="0"
sync_time="1"
reset_os_timezone=1
sync_os_timezone=1
[mapswitch]
[utility]
