Atualizações - 08/08/2011
Anúncios e Avisos da Administração MapaRadar
galonet
Registrado em: 03 Abr 2011, 21:56
Re: Atualizações - 08/08/2011
Mensagem por galonet »
Pessoal,
Boa tarde a todos.
Não sei se já é do conhecimento dos Srs, mas não custa acrescentar a informação se (não) for o caso:
Nova build do igo 8.3 (8.3.5.193799) de maio de 2011)
Link para produto pirata removido pela Moderação
e este post em particular:
"This version of igo 8.3.5 has made compatible with primo speedcams handling, so it support 32 speedcams. I don't know if earlier 8.3.5 versions supports. So, if you have speedcam text files with speedcams type: 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 and 31, the program will convert correctly, no longer assign the default one for these types. As, usual, the official data.zip is not upgraded to handle this, so I made the corrections to display correctly the speedcams and I added the ability to enter these type of custom speedcams."
"The speedcams type are:
Spoiler!: Click Here to show/hide the spoiler
Hidden text: OFF
0 Static
1 Mobile
2 Redlight
3 Section
4 Redlight Only
6 Railway Crossing
7 Bus Lane Camera
8 High Accident Zone
9 School Zone
10 Town Entry Point
11 Red Light and Speed Camera
12 Toll Booth
13 Hospital, Ambulance
14 Fire Station
15 Congestion Charge Zone
31 Dangerous Area
e
1- skin [igo83]Gurjon 6.18.4p_da de 29 de agosto de 2011:
Code: Select all
Código: Selecionar todos
http://www.mobilepassion.org/viewtopic.php?f=81&t=7049
"Changelog:
Hidden text: OFF
6.18.4:
- corrected the speedcam handling because from 8.3.5 versions 32 speedcam types are supported.
6.18.3:
-added omitted truck time settings and visualization
6.18.2:
-technical repairs (automatic day/night settings and route settings default page number)
6.18.1:
-Added 74 sign of DA
-made compatible with 8.3.5 version
-added truck profile module (like in 8.3.5 original version)"
2- skin Dimka WertVRV 1.1.46 -
Code: Select all
http://www.igo8mods.com/diMkaWertVRV_1146.rar
3- data.zip -
Code: Select all
Abçs
Caro galonet, já estávamos cientes desta nova versão e suas modificações. Também percebemos que as mudanças feitas pelo imre00 no data.zip e publicadas no MobilePassion estão incorretas, incompatíveis com os códigos anunciados (os mesmos do Primo). Quem usá-las irá encontrar alertas diversos do esperado.
Enquanto o data.zip e as skins não estiverem "estabilizados", de nada adiantará o Maparadar ficar correndo atrás, tentando se adaptar aos erros dos outros. Vamos aguardar até que a versão amadureça e fique estável, ok?
galonet
escadajr,
Obrigado pelos esclarecimentos.
Pergunta: existe algum data.zip indicado para este build mais recente do igo 8.3? Poderia fornecer o link? Grato.
Que eu saiba, ainda não saiu nada que preste... :D Nem o original eu consegui achar ainda.
galonet
escada, a proposito da nossa conversa:
"Well, you wont need that datazip anymore because here you have the original multiresolution data.zip for iGO8 8.3.5 ***** versions with ALL RESOLUTIONS (very hot, hot, hot !!)
Supported resolutions:
240_240/320_320/240_320/320_240/240_400/400_240/400_234/480_234/480_272/800_480/480_800"
links:
Working LINK:
MODERAÇÃO:
Esta mensagem foi editada e parte de seu conteúdo foi removido por violar as Regras do Fórum Maparadar.
Evite penalizações seguindo as Regras estabelecidas para este forum.
Poderias dar uma olhada?
Obrigado. :D
Obrigado, galonet! Não sei se você reparou, mas este data.zip postado pelo Gurjon é para o iGO 8.3.5.183522 (March 16, 2011). A versão mais recente, da qual estamos falando, é a 8.3.5.193799 (May 17, 2011).
PS: vou remover o seu link para os downloads do iGO, o que não é permitido pelas regras deste fórum. Abs!
galonet
escada,
Sinto pelo link direto, grato pela edição.
Quanto ao data.zip, me pareceu que seria para todos igos 8.3.5.******, ou seja, 8.3.5.183522, 8.3.5.193799, etc......!
No primeiro post do MP referente ao igo 8.3.5.193799 eles indicam (entre outros) este data.zip deste post do topico antigo do igo 8.3.5.183522, veja:
"links to Multi DATA: thanks to GJM
Hidden text: OFF
, e neste post deste mesmo topico tem um mirror valido
Link para produto pirata removido pela Moderação.
Detalhe, este data.zip não tem a pasta "ui_igo8_da", somente "ui_igo8". :?:
Cozzi
Registrado em: 23 Dez 2010, 11:05
Mensagem por Cozzi »
Olá amigos,
Estou com um problema que tem haver com este assunto.
Estou agora com um Apontador T-500 e tentando deixar o PRIMO, skin diMka P.1.3.5, nos padrões que gosto, porém estou com um problema para o Tipo de Radar 3 (Semaforo com Camera) que só aparece o desenho na tela sem "nenhum" tipo de aviso sonoro.
Vendo os Posts aqui, entendo o pq de não avisar a velocidade e não me importo com isto, mas gostaria muito do aviso da câmera.
Alguém sabe me dizer o por que deste bug e como resolve-lo???
Certo da atenção, desde já agradeço.
abçs,
Cozzi.
Cozzi
Pode ser que esta skin esteja no Padrão Europeu que difere dos types utilizados no Brasil.
Cozzi
Pensei mesmo que o problema fosse da Skin...
Vou baixar outras e testar tbm.
Vlw. gde abç
Voltar para “Anúncios”
